Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-16-2019   #1
bopatn
New Member
Equipment: kubota 1550 hse
Default B1550 Mower deck hanger bracket bolts falling out
For some reason these bracket bolts keep falling out. There are 3 that hold the bracket to attach the mower deck onto the frame on each side. Anyone else having this problem and how did you fix it?
bopatn is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-16-2019   #2
SidecarFlip
Master Tech
Equipment: M9000HDCC3 / M105X / M9000HD
Default Re: B1550 Mower deck hanger bracket bolts falling out
A wrench?
SidecarFlip is offline   Reply With Quote
Old 04-16-2019   #3
leoric
1st Yr. Apprentice
leoric's Avatar
Equipment: B2650 since 2018. BH77, LA534, Forks, 60" Bucket, 60" Mid mount mower
Did you try blue loctite?
__________________
B2650 with BH77, LA534 loader, Forks, 60" Bucket, 60" Mid mount mower
leoric is offline   Reply With Quote
Old 04-16-2019   #4
Master Tech
Equipment: BX2360, FEL, MMM, BX2750D snowblower. 1953 Minneapolis Moline ZAU
I might try a stop nut or lock washer and/or blue Loctite.
RCW is online now   Reply With Quote
Old 04-17-2019   #5
bopatn
New Member
Quote:
Originally Posted by SidecarFlip View Post
A wrench?
That's funny! I think the problem might be that instead of the frame being threaded (for the bolts) they tacked nuts on the inside. It's a box or a square tube that's only open on one end, not the backside, and there's no room to get a wrench in there. The bolts won't thread so I'm thinking the nuts fell off. This is what I'm trying to determine. Guess I wasn't as clear as I could have been initially.
With so many of these units out there I doubt mine is the only one loosing bolts. If you've had this issue I'd be interested to know how you remedied it.
Thanks
Old 04-17-2019   #6
bopatn
New Member
Quote:
The bolts won't start to thread, I was wondering if, instead of threads in the frame they tack welded nuts on. The problem is that the brackets attach to square channel that's enclosed except for a small area on one side. I wanted to attach a picture from my manual which shows this but they wouldn't allow me to do so since I'm a new member. Anyway, I suspect that the nuts are now gone. If anyone else has had this problem I'd be interested to know how you remedied it. Six acres of rapidly growing grass await! Thanks
Old 04-17-2019   #7
bopatn
New Member
The bolts won't thread. Is it possible nuts were tacked on but now they've fallen/vibrated off? There's no room to access the area where bolts thread into, it's enclosed except for a small area on the side.
If you've had this problem I'd be interested to know how you fixed it. Thanks
Old 05-01-2019   #8
bopatn
New Member
Thumbs up Re: B1550 Mower deck hanger bracket bolts falling out
It's fixed! I took off the right side step then removed the parking brake pawl to gain access to the backside of where the three bolts fasten the hanger bracket. There were nuts there that were tack welded but the welds broke so the bolts either fell out or wouldn't tighten. Taking the step off and removing the pawl allowed my grandson to get his skinny fingers in there to get lock washers and nuts on the bolts. Now they should stay good and tight.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
