Are any after market tires the same size as kubota
man00
197
10
okla
I seen a few tires (don't recall who sold them) that had the same tire size stamped on tire but was smaller than the original tire that came on tractor.
I ran into this on a zero turn mower..this one was a Carlisle same size on tire but was about 1" taller, but fit the rim fine.
4,856
Your going to have to be a little clearer, and more specific, at what tire and for what, that you need it for.
man00
197
10
okla
B2320DT///I found aftermarket tires but the ones I seen (and that is a very few) have not been the same size as the originals even when they both have the same sizes on the tires...Sorry kinda hard to type what I want to say
4,856
Ag's or turfs.
What size are on it right now?
And 1" taller is probably not going to hurt it at all. ;)
BAP
Dec 31, 2012
2,513
657
Kubota does not make tires. All tires put on at the factory are sourced from tire manufacturers. To buy new tires you need to look at what the tire size that is currently on your tractor and what type, AG or R-1, Turf or R-3, Industrial Bar R-4. A good tire dealer that deals in heavy truck tires or off road equipment tires can usually get them for you.
Missouribound
Jun 17, 2014
646
37
Missouri
Does anyone know if there is a tire chart available that would show which tire ratio would work on a given tractor? I'm sure you can find tires to fit your rims but in 4 wheel drive you risk some drive train damage if the ratio was wrong.
man00
197
10
okla
Ag's or turfs.
I'll get the sizes and post, I think they made by Titan.
Made a huge difference on my badboy mower, not only was one side higher than the other but prevented me access to grease zerk and that tire had the same as the one that came with the mower. I know the tractor is totally different but I just like to keep things close as possible as they suppose to be,,,
Thanks
4,856
No they do not, it would be nice to have though... ;)
man00
197
10
okla
This is why I ask, pic may not show that much difference in the tires but there is. Both are stamp as same size..one on left came with the mower the other is a Carlisle.
I don't know why it shows sideways?
Louisianna
bx2200
Feb 11, 2021
illinois
prioritytire.com I recently purchase the btk 8 ply for bx2200 - front and rear
punch in your tire size and see your options
advise - if you have 4wd must keep same diameters you have or risk damage 4wd
for you math wizards - tiresize.com - calculate and go for broke
thirdroc17
185
35
It appears the right tire has more air pressure in it. It's sitting in a much "rounder" profile whereas the left tire is flat across. If you run a tire with lower air pressure for a while, it will take on the flatter profile and stay flatter across even with the same pressure.
Are they the same ply?
Exact sizes do vary between manufacturers and even different lines of the same manufacturer.
200mph
Mar 3, 2017
1,228
58
PA
The OP can check the tire specs posted by each tire manufacture to verify they are the same. 5 minutes searching will uncover the manufactures tire catalog with all the tire specs.
If the tire doesn't match published specs, take it up with the supplier/manufacture.
After verifying tire pressure are equalized, actual measurements would be more precise than a picture.
For these size tires, it might more economical to purchase the tire and wheel assembly through wholegoods. Thank to pay for just the tire, mounting and new valve.
