steering mishap
clutchdog
1998 L4200D
Jan 8, 2015
Bay Port, MI
Howdy,
Plowing snow the other day. Lost steering control. My pitman shaft fell out due to worn plate shaft. Ordered a new shaft with bushings and seals. Tried to install the shaft but the upper and lower pitman arm holes do not align. I have pulled the radiator in order to expose the arms. Anyone have any guess as to why the arms do not align? I will know more tomorrow.
What is the trick to getting the tie rod ends out?
6,345
#1 can you tell us which tractor your working with??? :confused:
If you put it in your profile that helps too. ;)
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum. With a little more info, you might get the help you need.
clutchdog
1998 L4200D
Jan 8, 2015
Bay Port, MI
1998 L4200D Ser# 55798. I have resolved the pitman shaft issue. The upper pitman arm hole was burred. Having a time removing the tie rod ends so I can replace bushings and seals in the assembly arm, pitman. Do I need to remove the clips first? Thanks for any reply.
Clutchdog
