Attachment Pin for Drop Drawbar w/ Clevis Kit - Help Needed
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Hello Guys, Can anyone provide me with the correct part # for the Attachment Pin I need for Kubota Drop Drawbar- BL6820 being used with Clevis Kit- LMX6800.
This drawbar is used for LX, L, MX, tractors.
I have not had much luck finding the correct Pin for this configuration. So far the Pins I have been told to use are too small a diameter to fit correctly in the drawbar. The Drawbar/Clevis hole diameter is 1.25" (1-1/4") The pin I have been told is the correct pin (99533-78250) for this setup is just under 1" (0.94").
To me, this pin seems a very sloppy fit, rattling around in the larger hole.
Thanks, Dan
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Thank you Russell, I appreciate your suggestion.
NO that pin would not work. That pin appears to be about 4" long. The pin I need would be longer. It would need to have a shaft with a minimum 5-3/8" in length from the top of the pin to the hole to secure the pin.
I'm hoping someone would know what pin would work for my application.
5,391
Like this?
3,155
4,238
Would 1-1/4" precision ground shafting be good as the pin ? I 'saved' 2 pcs 8 feet long from going TO China the other day. Also grabbed 8 pcs that are about 8-1/2" long. At least they don't take up too much space while I await ideas on what to use them for.
3,155
Where was the shafting produced… :cool: …. and is it hardened…?
I ordered some 1-3/16” shaft from McMaster-Carr…. and thought it surely came from Pittsburgh or some such… Nope. China.
Nowadays…If stuff comes from off-shore… I try to buy Taiwan https://www.trademo.com/taiwan/manufacturers/steel-shaft
or Ukraine
