NO not one pushes out, they both pull in.
Here is Exactly how to do it.
To verify the white is hold and red is pull, touch each wire, only one will snap, that is the pull in coil, it should be red.
Have a power lead, put one wire on the white wire, nothing happens, keep that wire on and touch the red wire momentarily, you should hear /see the rod pull in and stay in, it will stay in safely without burning the coil up for as long as you need, hours if you so desire.
keeping the white wire on holds the coil in.
If you keep a wire on the red ( pull in coil ) too long that will burn it up.
This is where the rack pin goes.
