G1800 water pump removal
bjmsam
L3710 HST, G1900-S
Feb 19, 2010
9
Mount Airy, MD
I'm preparing to do this on my G1900 but the rest of your post does not appear for me. Can it be done with the radiator in place? If not, then to remove it, some say pull the engine, some say pull the dash. What approach do you suggest?
2,433
I have no direct knowledge of your machine, but "in general" I fid it much easier/safer to remove a radiator when replacing a water pump.
One slip up and "bam" the something hits the radiator and put a hole in it.
I am quite sure there are exceptions to my "rule".
Someone more knowledgeable will be along shortly I'm sure.
Good luck either way.
