mcmxi
5,774
NW Montana
I used the MX for about 15 minutes to flip over an outboard engine stand that I built today. It took longer to get the bucket off and pallet forks on than it did to flip the base for the stand.
4,093
Played around with and adjusted some attachments I bought today View attachment 127595 View attachment 127596
I have an old blade similar to yours which I inherited from my father. I have used it occasionally for almost 50 years. Walked by it in the shed the other day and it struck me that the extra holes toward the top of the blade allow for shifting the whole moldboard to either side by removing the bolts and mounting it using the offset holes. Felt brilliant for about a quarter of a second and since have felt like an idiot for not recognizing that at least 40 years ago. Pretty sure everyone else with a similar blade already knew about that feature.
Reactions: 6 users
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
583
420
central ny
I have an old blade similar to yours which I inherited from my father. I have used it occasionally for almost 50 years. Walked by it in the shed the other day and it struck me that the extra holes toward the top of the blade allow for shifting the whole moldboard to either side by removing the bolts and mounting it using the offset holes. Felt brilliant for about a quarter of a second and since have felt like an idiot for not recognizing that at least 40 years ago. Pretty sure everyone else with a similar blade already knew about that feature. View attachment 127623
My old ford blade has that feature and I have used it a couple times on the ditch along the gravel driveway. But not in a long time, I found just running the tires in that ditch a couple times a year opens up and keeps it flowing
L35
Jun 13, 2010
472
313
CT
S-G-R
LX3310
Jun 17, 2020
1,067
2,163
PEI Canada
I watched my neighbor lime his fields but for some reason he chose powdered. Same style spreader as yours. I think the lime went everywhere but on the field.
I'd prefer powered but use pelletized for the reason above. A friend built a nice drop spreader that he uses behind his B2650 that applies a nice, even coating.
g_man
Feb 3, 2023
142
618
NE Vermont
I use my blade offset during mud season when I don't want to run the tire to close to the soft edge but I want to dress the edge to let the water run off. Changing the blade over to offset looks easy but I find it to be a pain.
S-G-R
LX3310
Jun 17, 2020
1,067
2,163
PEI Canada
You mount your blades backwards to use it like a drag ??? Good idea. Have not seen that before.
gg
It's an option to have rear mouted blades. I find by going backwards you can polish the finish coat off better.
4,653
Powdered lime is less expensive than pelletized, however, you need a drop spreader to spread it. I buy my powdered lime at Tractor Supply because they sell a 50# bag for $3.99.
L35
Jun 13, 2010
472
313
CT
Less expensive, that explains it lol.
mcmxi
5,774
NW Montana
Whoa! Is that guy wearing a dust mask? I'm hardly one to talk though. I spent the day yesterday cutting, grinding and welding without a dust mask and can feel it this morning.
L35
Jun 13, 2010
472
313
CT
Nope
MOOTS
MX6000
Jun 27, 2019
1,864
2,112
Canton, Georgia
Is lime dust ok to breathe?
According to the label on our bags of chalk for ballfields, which is just powdered lime, it causes California in cancer. What doesn’t these days?
Our turf guy just put out pelletized lime on all of our fields.
4,924
EA had a MUCH better (easier to use) idea for blade offset, with their "6 Way Deluxe Scrape Blade".
All gone now,.....but I am thankful that I did buy one of theirs.
I have a new 7' King Kutter, with offset much like this one shown, and it needs another home.
Foxrunfarms
Kubota LX2610, 1951 Farmall M, 1967 John Deere 110 Rf, 2010 Arctic Cat 700
Apr 25, 2023
366
522
WI
Mine is an imco. Ppl say it's light duty, but seems about the same as the dearborn I had. It's probably not extremely heavy duty, but sure a lot thicker than the in store brands. I'm pretty sure mine was used as an offset......new bolts and nothing is rusted up. Kind of a chore to do but still probably better than then new style.
