B2601 3pt left tilt
msmcknight
75
Statesville, NC, USA
Hi All,
I have a B2601 and need to be able to tilt my box blade to the left but only the right-hand lift rod is adjustable. I tried swapping arms from one side to the other, but as I'm sure most of you know, that doesn't work.
Is there an adjustable left-side lift rod like the one on the right? I can't seem to find a site online that simply lists all of the optional components available for my tractor. I don't need a hydraulic one, just a simple turn one like the stock one on the right.
Any pointers, with a part number if possible, would be appreciated.
Thanks in advance!
4,093
Not specific to your model tractor, but usually the fixed link only fits on the left side but the adjustable will fit either side. If you don’t require Kubota OEM, measuring the max/min length on the adjustable you already have and picking up a generic with an acceptable length range may be a cost effective option that’s easy to source. Not saying the below is precisely what you need but as an example:
4,700
OK, I'm curious...
Why can't you swap the adjustable lift rod for the fixed one ?
I looked a the online parts drawings and the lower links (arms) are the same part, I assume the rockshaft lift ends are the same. Nothing stands out in the drawings as to why they can't be swapped....
2,711
1,451
I'm curiouser. Why can't you lengthen the one on the right to tilt it to the left?
There was someone on here not long ago thinking about putting adjusters on both sides.
msmcknight
75
The left side arm is shaped in a way that when you move it to the other side, rotating it so it would seemingly match the other one, the welded bracket at the bottom is at the wrong angle and won't fit around the lower arms. I was completely surprised by this as they "look" like they should fit, but nooooo.
I'm not sure where you saw the part list showing the lower link rods being the same part. From the factory, the left side is a fixed rod and the right side is adjustable. You can kinda see it in the diagram below, notice the right side (#6) is different from the left (#3).
I have raised the right side to tilt the blade to the left some, but I'm trying to level a spot on a sloped bank and the obstacles around me make it so I can only pull from one direction. I can't even push into it from the side to try and dig it out a little. The slope of the hill is just a bit more than I can cut with one side raised. It doesn't raise high enough. This is probably a job for a skidsteer, but I don't have one of those!
I've been working back and forth with the bite I can get, but it's still about 2" from being level and with the tractor sitting at an angle, I'm just not biting deep enough.
2,711
1,451
The lower clevis often has more than one hole. Maybe you could temporarily use the alternate hole on one side?
4,093
You’re exactly correct about that little bit of angle being the problem with swapping. It’s also a “problem” moving the adjustable link to the left side but with the adjustable link it’s easily solved by turning the bottom a half turn while leaving the top stationary. That puts the little angle in the correct direction to fit the left side. So your fixed link only fits the left side: adjustable should fit either side.
My L works the same way. Our 9N worked the same way. Our H works the same way. And all of them have adjustable side links on both sides.
Before you spend any money, test this for your specific tractor by taking the adjustable link off the right side and confirm you can put it on the left side by simply reversing the angle on the bottom half of the link. If you can, and there’s a 99% chance you can, you’re overthinking and overcomplicating a common simple problem that has a common simple solution: just buy an additional adjustable link, which could be another OEM or a generic AM, and run an adjustable on both sides.
If you attempt to move the adjustable link from the right side to left side and a simple half twist of the lower clevis end doesn’t make it fit, my sincere apologies, but it’s a relatively cheap, easy solution that has solved the exact problem you have on every tractor I have and many others in our hilly area where the issue you have is pretty common.
BTW: Looking at the pics below, the sidelink clevises probably all look straight but, just like yours, they all have that little angle.
Shadetree605
kubota b2100
May 1, 2022
212
100
north little rock, ar
Unfortunately, the lower clevis on my 2601 only has one hole on both the fixed and the adjustable rods.
not the down links...the arms that they attach too, there '' should be '' about 2-3 holes that go outwards along the lower lifting arms ?. if you have them ?, move the left side lifting link that attaches to the lower lifting arm on a further outwards hole.
Smokeydog
Jun 2, 2020
641
582
knoxville, Tennessee
The 3pt lift arms on my B26 has two holes. Installed geared side link adjuster (Weaver Tractor) and Pat’s quick hitches (longer arm length) gives easy and good amount of adjustment for grade work. Did require a little bit of fabrication.
4,700
msm's drawing nicely shows the extreme angles the 'lift rods'(3 and 6 ) have,unlike the parts page.
all my tractors (older, like 5 decades ..) I can swap lift rods. it might be a size/design challenge, hence the big bends. I have a 9N adj lift rod on the shelf here,just no tractor for it.
It's the 'lower links' that are the same part numbers, just flipped over.
Grandad4
Apr 5, 2016
304
64
Greensboro, NC
Shorten up on right to have the left side tilt.
Yes. On both of my Kubotas (Grand L and BX), adjusting the right 3 pt link to its midpoint made the implement level, lengthening the right link tilted the implement down to the right, and shortening the right link tilted the implement to the left. Each tractor would tilt the same amount in either direction.
The amount of tilt available in the 3 point arms is not great, maybe 10 degrees or less. Implements that might need more tilt usually can be found with built-in tilt features. An offset rear blade, for example, usually can tilt up to 45 deg. for ditching, etc.
Maybe not a great idea to get the 3 point arms too far out of their standard triangular attachment geometry, hence the limited adjustments?
4,093
Don’t know if it’s a good idea or not but with an adjustable link on both sides I run mine well past 10 degrees without damage. Admittedly a different model.
Mikeymotorbikey
B2601, Case 446, JD4475
Jun 30, 2022
22
11
North Branch, Minnesota
I've been contemplating a hydraulic tilt link and my plan was always to move the right, adjustable one to the left side and add the hydraulic to the right side.
As the OP has noted, you can't just swap links from side to side. Well, you can with the adjustable, it's not orientated correct any more but it would work. The left fixed link will definitely not work on the right side.
I've only ever seen a hydraulic link on the right side of a tractor.
Is there any magic to this?
Can a guy add the hydraulic link to the left side and keep the adjustable on the right side for "double adjustability"?
4,093
[/QUOTE]
It’s probably a throwback to the 3 point plow days. For a moldboard plow where the first row is on flat ground and subsequent rows are with one wheel in the ditch you just plowed the adjustment is preferable on the right side based on my distant memory of plowing with a pair of 16” moldboards.
I have no hard evidence to back that up, but that’s my theory.
Edit: And all 3 of our tractors (one of which has moved on to a new owner) have adjustable links on both sides. My L has the hydraulic on the right and manual on the left. I rarely move the manual but there are times it’s useful to have the option to adjust either or both.
