Differential lock
Moldel t guy
1978 l225
Oct 23, 2022
N.C
While changing the transmission fluid the 23 mm bolt on the left side was pulled out. This apparently let the pedal for the diff lock move left. Now the bolt will not go all the way in and the pedal is locked. How can I get this back?
2,426
We are assuming it is on your L225?
Alanmexico
L2000dt
Jun 3, 2022
9
Banana, Qld, Australia.
Have you had any luck yet?
I can't see how removing the bolt could cause a issue.
But it's not a huge job to remove the top cover/hydraulics to find the trouble.
Moldel t guy
1978 l225
Oct 23, 2022
N.C
No I haven’t, it’s working without it but I have no diff lock. I can’t find anything on it in a manual or parts breakdown.
thanks for asking
2,711
1,451
thanks for asking
That plug may support the shaft. Maybe have someone jiggle the shaft while you screw the plug in? If that doesn't work, it's right there when you remove the top cover.
Moldel t guy
1978 l225
Oct 23, 2022
N.C
The plug does push against the shaft. I have jiggled wiggled and pulled it out as I’m tighteng the plug but it’s a hard stop before it get in all the way.
Alanmexico
L2000dt
Jun 3, 2022
9
It's a real tight spring!
A real bugga to install 🤯
This might help 🤷 [ATTACH said:
93333[/ATTACH]
Sorry this is the only pic I have with the shaft, not showing the other end.
There is not much involved with it.
Only thing I could suggest is remove the plug & try to centre the shaft with a screwdriver.
"Moldel t guy, post: 602956, member: 54999"]
thanks for asking
