2022 Kubota LX2610 jerky
jrsavoie
2022 LX2610, 1963 JD4010, 1975 Ford backhoe, 1996 Toro 223D, 1999 Toro Groun325D
May 3, 2011
155
34
Clifton, Illinois
Our new. 2022 LX2610 seems very jerky. Try as we may to be gentle on the controls the loader and forward and reverse seem very jerky. It's a good thing we had the sprayer strapped to the forks or my wife might have flipped it clean over the back of the tractor. Just trying to roll it back a might.
My wife is used to me on other equipment and keeps getting to close when I am operating this machine. Causing me to yell at her.
Had 2 friends run it with the same opinions on the jerkiness of operation.
Are all Kubotas like this?
Is there a fix?
Other than toting the sprayer around for a few hours yesterday, we have maybe 1/2 hour on the machine. Mostly getting it out of the shed so they could take it back to the dealership and unloading it when they bring it back.
3,102
Just a thought, but how about going back to the dealer and trying out the loaders (and so on) on a few different tractors, to see if yours operates differently.
If yours is considerably different, get them to fix it.
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Grapple, Z421
Sep 26, 2021
245
478
Buckfield Maine
I have found that running at lower rpm's takes alot of the jerkiness out of the loader and making finer moves in low range helps too.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
I don't have much time. But that's a good idea.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
We were running at idle and a little above.
dkelley360
LX2610
Mar 16, 2022
I have a 2022 LX2610 HSD with the cab. I have 52 hours on it now. Mine does not feel overly jerky going forward, backward, or with the loader. Everything operates very smoothly. The only time I get a slight jerk is if I'm taking off in high at about 1700 rpms.
Bdubz
LX2610, 60"MMM, FEL, Grapple, Box Blade, Tiller, Moldboard Plow, 5' Snow Plow
May 18, 2022
20
20
Western New York
Do you have any noises coming from the 60" MMM (if you have one) when lowered down past half height?
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
So is there an adjustment that needs to be made?
dkelley360
LX2610
Mar 16, 2022
I do have the 60" mmm. I've cut with it twice now and so far I haven't had any weird noises. I did see your thread about it. I'll be cutting grass tonight so I'll pay closer attention to it and let you know if I hear anything like what you described. But I am also set at the 2.5" height.
dkelley360
LX2610
Mar 16, 2022
Not that I am aware of. If yours is so jerky that you almost lost the sprayer off of the forks I would think there is something wrong with the system. That seems excessive to me.
Bdubz
May 18, 2022
20
20
Western New York
Thanks, I'd appreciate knowing if you hear anything. The easiest way for me to replicate it is the have the mower fully raised, engage blades, adjust rpm to about 2500, then slowly drop the deck. The noises kick in about half way down and then continue until raised again.
dkelley360
LX2610
Mar 16, 2022
I'll give it a try and see if I hear anything
Fly5guy
LX2610 Cab, R14's filled, LA535, SGC0660, PFL1242, RCR1860, LR1672, STB1072
Apr 14, 2022
84
80
I have about 6 hours on my new 2610 cab and the only time I feel like it jerks is when I am trying to creep backward, it will slowly move then it jerks and you an hear the trans get louder. It does not do this in forward. The only other function that seems jerky is the FEL tilt forward or down but it seems like the stick is more sticky then it is the hydro. If I give it a quick push then I can feather all I need. Its just that initial input that drops those forks pretty quick. I test drove a different 2610 with a cab as well at a different dealer and that one was very jerky on the forward and reverse.
PA452
B2650
52
Western PA
This is what I'd suggest. Maybe it's just not what you're used to compared with other machines.
I don't consider the controls on my B2650 jerky, but I try to work them with a soft touch.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
3 different people. Same conclusion. It's mostly roll back and tilt.
No matter how hard you try to ease into it, it does the big flip.
Never had a piece of equipment I hated so much and haven't used yet.
If it was in my name, it would have been returned weeks ago.
Rwire17
LX2610SU, LA535, BH77, BB1260, PFL2042. Cub Cadet ZT2
Jun 28, 2021
14
40
Sidney,NY
I have just 10 hours on my LX2610SU and It doesn’t feel jerky to me at all.
It actually feels very responsive.
Maybe it’s just what I’m used to, because I don’t have much experience operating a tractor.
Norman
LX2610HSD;LA535;LP 60" grapple; WC68 chipper; GB60 SW cutter
Sep 30, 2021
84
97
Georgia, USA
Have 50 hours on mine and I find the stick is very responsive, meaning, small movements result in just the right amount of bucket/grapple movement without being jerky. When I occasionally move the stick too quickly or too much it will jerk for sure. It's taken some practice but I can finesse it pretty well now without issues.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
I consider my wife's 2022 LX2610, dangerous. Everyone has to stay clear anytime anybody is on that machine.
3,102
As I started to read your post I thought it was intended to be humorous, and was going to end with:
...Everyone has to stay clear anytime SHE is on that machine. :ROFLMAO:
Elliott in GA
Mar 10, 2021
762
751
North Georgia
95+ hours on LX SU - no problems with the FEL controls/response or any lurching with the transmission. I have leveled 3 sites with the FEL and box blade (largest 30x30 feet) and moved/spread over 85 tons of gravel on the sites and driveway.
