4,093
Church needed several hundred yards of silt fence removed. T posts, 2” square wire, and poly burlap. If course you usually don’t need a silt fence in a flat field so it was an interesting exercise getting to them without landing on my head. Picked up a T post puller from Tractor Supply for about $12. Wife hooked them up. Grapple worked pretty well for ripping the wire out and stuffing it in a dumpster, too.
Loaded up and ready to roll out.
A tame section of the fence which must go. There’s a lot more on the 50+ acre property.
The simple flat 1/2” plate at the end of the chain is the T post puller. Worked very well. Quicker, easier, less likely to slip than a chain by itself. Hole with a chain slot on one end; square hole capped with a triangular hole on the other to grab the post.
There was a guy out there with two very dull chainsaws and his pre-teen sons trying to cut some deadfall into small pieces to carry about a couple hundred feet out of the woods to his trailer. He couldn’t figure out why his nice Stihl saw was cutting like the backside of a butter knife. Talked him into cutting them into lengths to fit his trailer, skidded them out for him, and loaded them on his trailer. Suggested he take the chain to a local saw shop for sharpening or replacing before messing with the logs further. Partly because I’m sometimes a nice person. Partly because his operation and ours were kind of occupying the same space.
Reactions: 6 users
Ridelght
2022 Kubota L4060 Polaris Rangerxp800 Ford 3400
Feb 16, 2022
434
293
Church needed several hundred yards of silt fence removed. T posts, 2” square wire, and poly burlap. If course you usually don’t need a silt fence in a flat field so it was an interesting exercise getting to them without landing on my head. Picked up a T post puller from Tractor Supply for about $12. Wife hooked them up. Grapple worked pretty well for ripping the wire out and stuffing it in a dumpster, too. View attachment 76087
Loaded up and ready to roll out. View attachment 76088
Thats a great tip about the T post puller. Funny story about the Stihl saw. If deadfall he probably hit dirt. Then wondered why so hard to cut.
It serms grapples are the bomb. My next purchase i think.
Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
306
Grafton, Ohio
What did I do to my Kubota today? Nothing. I stood next to it in the garage and looked at my muddy yard and said “too soon”. It was 70 and breezy so the ground is getting better but not quite there yet. 😡
Reactions: 6 users
Ridelght
Feb 16, 2022
434
293
Lol.....yep...
jyoutz
Jan 14, 2019
2,851
1,893
Edgewood, New Mexico
Might have missed you mentioning this elsewhere -- which canopy is that on your MX?
My dealer installed it, but this is the one:
It is steel and holds up to being trailered.
Trapper Bob
Jan 17, 2022
444
800
Andover, KS
Cut some more trees today & made a decent brush pile. The trees are mostly hedge, cedar & black locust. I hope the tires (R4) hold up to the black locust. I put “Liquitube” in all 4 tires. Those thorns are evil looking.
MOOTS
MX6000
Jun 27, 2019
1,864
2,112
Canton, Georgia
They will not. The leak stop may help some, but I’d carry some plugs and tools with you.
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
142
249
St. Clair, MO.
Here are my plans for when my dealer finally tells me the BH70 has arrived for my little B!
Jsjac
B2650
Feb 13, 2022
172
236
I plowed the snow of the vegetable garden spot.
Maybe it will be dried out before the end of May.
Looking forward to spring this year
Kmyers
L3301 - loader, tiller, mower
Jan 15, 2019
26
Some driver decided to leave this when he washed out. Moved it into the creek bank
4,924
Ridelght
Feb 16, 2022
434
293
Those thorns are on a Honey Locust tree, not Black Locust.
Moved some big rocks with a jib grab from a island between my 2 drives. Going to widen the drive by reducing length and make the circle drive better. Still mostly mud. Would rather move drier dirt later. Taking dirt to a low spot and made a mess so i stopped for now.
4 weeks old amd missing paint on the bottom of the bucket. Now its a tractor.
forky
L2501 HST 4X4 8N
Feb 23, 2021
262
271
Wisconsin
I like the jib grab! Where did you purchase that? I could use one of those for sure.
MOOTS
MX6000
Jun 27, 2019
1,864
2,112
Canton, Georgia
How much weight did that add?
Kubota rates the weights at ~103lb per. There are 3 on each wheel. Plus the hardware, that looks like 7/8” lag bolts. Tires are loaded too. And I have a ballast box I need to fill.
2,711
1,451
Also known as log lifting tongs. Different sizes available from Northern Tool and others. OP's look like the ones on eBay.
Fordtech86
L3200
Aug 7, 2018
4,976
5,912
Pineville,LA
I just watched 😁
and just for the record, he is 7 and its a DT tractor, not a hydro…while I doubt I will have to put a clutch in it, I could care less if I had to. The experience is worth it to me
Reactions: 10 users
