zload
B2400HSD/47 John Deere Model M
Apr 14, 2015
91
FL
Not today but last Saturday I hooked up the middle buster plow and dug 400# of red and white new potatoes. On the way home I called my buddy who is a local chef and sold 200# to him, truly farm to table as they were in his produce room before they had been out of the ground 24 hours. Yield was right at 10# of potatoes harvested for every 1# of potato seed planted. Also pulled 30# of sweet onions but the tractor was not involved with that:). Been delivering excess potatoes to neighbors, family and pastor... and ate a few as well.
otter
L3800, LA524 loader, BH77 backhoe, thumb, box blade small wood lot log grapple
Sep 26, 2014
52
Chase, Alaska
Layed out and dug 20 holes for the new shop posts.
A moose walked through the string lines so they needed to be redone.
mudog88
1982 B7100HST-DT, RC60-71H MMM, 5ft. back blade
Aug 11, 2015
100
Pine Village, Indiana
Saturday I mounted a set of gauges to my little tank. Oil pressure, water temp and voltage. Followed Hokie's How-To and it was great (Thanks for that!). Haven't had a chance to actually start it up to check everything out, but I did crank it over with decompression lever pulled, and it ran up to 40psi quick and held solid there. All-in-all, I'm happy. Will post up pics soon to prove it. :p
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
Well, I did nothing to my tractor, since my B7100 is 100 miles away. But, I did order me a Piranha tooth bar for the bucket today and a Pat's quick hitch set up.
sawmill
bx24 backhoe/fel, 48" Bush mower
Nov 16, 2014
567
125
ione, washington
Today I removed the cab and backhoe from my bx24 and put my Bush mower on. (After a skinned knuckle and a few choice words) I did some mowing. :)
SDMauler
2009 BX2360TV60, RCK60B-23BX
Aug 8, 2014
82
Parker, SD
Hodge, I agree you 100%. This whole conversation about welding on a ROPS is precipitated by protecting corporations from litigation.
I think America would be a better place if all law schools were shut down for at least 10 years. Those folks have to make a living and and law suits present opportunities for that.
You know what they call 10,000 lawyers at the bottom of the ocean? A good start!
Lennyzx11
L3301
Dec 18, 2015
Bennington Vermont
Started clearing out a relatively flat place down below the house in the woods that I've been meaning to.
Used the back blade to clear the leaves, mulch and loose rocks.
Used the grapple to dig up cedars that had grown into it over the years. I found that the grapple does an excellent job on up to about 5" cedars if I push it over first, then back up and run the tines under the roots. Curl back and maybe some forward movement popped them up and closing the grapple grabs em to move to burn pile. The hardwoods were a little tougher and the smaller stuff seems to be a PITA for the grapple slipping between the tines so I'm putting the bucket and piranha tooth bar back on to try on those today. Used the back blade to clean out the natural spring nearby this spot.
Took about 4 beers.
5,225
I wondered, where in Ok. are there that many trees? Then I looked up where you're located. Only a few miles from Ark.
Looks like you're having too much fun!
2,444
Always seem to work right through lunch & sometimes late into twilight, so I added a cheap stick-on automotive dash clock.
billrigsby
Mar 17, 2015
1,017
201
Florissant CO USA 8213'
www.facebook.com
Finally got to get some work done on " ??? " , still working on a name for her.
Did some more fab work on the replacement battery tray,
cut it down to the correct size
and welded it up (ugly I know)
added the hood supports an it got a coy of paint
Still needs some "cosmetic" work so it looks better
Got my hydraulics hooked up
and got the fuel system plumbed in (I know I bought 4 new clamps, can't find one)
Gonna have "fire in the hole" soon, hopefully after all this she will start right up ? :rolleyes:
Did I mention I found a GOOD (REALLY GOOD) :) front bumper, that will save a lot of fab work,
thanks Russell for all the dimensions and pictures, almost glad I don't need them any more !
But I do enjoy that kind of work :D
billrigsby
Mar 17, 2015
1,017
201
www.facebook.com
Installed the new (fabbed) battery tray, it is not perfect but once there is a
plastic liner and battery in it, it will look fine, better than the corroded one.
Looked over the new (to me / used) front bumper, need to get going on repainting it.
1,267
Odd your bumper has no holes in the bar like mine does to bolt weights in place
billrigsby
Mar 17, 2015
1,017
201
www.facebook.com
I did notice that also ?
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Brush Hog 48" "Squealer Mower"
Atlas 48" Landscape Box
Rhino 48" Rear Blade
Draw Bar with 2" Ball
28" Fork Lift Forks
36" Sears Snow Blower (still to be mounted to the front PTO)
Sent from my Samsung Galaxy S7 using Tapatalk
trapperdrew
2017 BX23S TLB
Dec 16, 2015
116
Got my 50 hour service all done [emoji2] then went back to moving 15 more yards of stone dust for the new patio.
