![](http://images.tapatalk-cdn.com/15/09/16/5a79bc5e9b0e2f9d8c86b6d6bb656ace.jpg)
Then today loaded it up and went and did some dirt work for a customer that wanted more dirt put on his septic lines.
![](http://images.tapatalk-cdn.com/15/09/16/af73613d1c8598feacf0f9a9fb76376b.jpg)
![](http://images.tapatalk-cdn.com/15/09/16/3326bc665dba918c53765ba7ac2c7d13.jpg)
I think he's jealous of the competition, checking it out and all.Cleared pasture fence. Had way to much help. The White one says "let me drive it"
I brought about a pound of them with some nuts n bolts from tractor supply for $3. Why buy a single bolt for $2 a piece. Can change sheer bolts in 5 minutes with a 7/16 and 11 mm wrenches.Standard Grade 2 bolt is all a sheer bolt is. Even Kubota admitted that in a manual I read on one of their equipment items. Your hardware store has them.
Your overheat problem may be caused by a plugged radiator. Yes, I know it can look really clean, but trust me, it's not. Flush those fins out with a strong water stream followed up by some compressed air. You'll be surprised at the difference. Of course, all of that is assuming the water pump is working properly, so I'd check that first.
All work for myselfolthumpa, you have that all logged out like you're on the payroll! You got your eight hours in before clean up. Who you working for, clean up should be on the clock to.
Just joshing you, I hope you know! How much fuel did you burn?
Whoa! Hope you got pics of that, or better yet, a vid! Wish you'd done that 4 months ago, maybe I coulda saved a K or so... <sigh>Not so tough now are you, big tree?
-- Carl
