B2320 - feathering three point, not great
PWarton
17
New Mexico
I've been doing some scraping with my box blade but the feathering for the 3 point on my 2009 B2320, is let's just say, almost non-existent. Is there a cheap fix for this?
5,908
Simple answer NOPE, it's called a 1/4 inching valve.
BigG
Sep 14, 2018
1,951
768
West Central,FL
If you can add a hydraulic top link to the tractor then you can use the top link for very fine control. Not the best way but doable.
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
Does that model offer a draft control? Keeping the control lever pivots is a big help on the larger M and L series.
SDT
multiple and various
Apr 15, 2018
3,206
1,011
SE, IN
Neither position control nor draft control.
Only quarter inching valve.
leveraddict
Apr 1, 2019
907
588
NEPA
Bring the tractor down to idle and the quarter inching valve positions much better!
4,783
It takes some practice, but I can kinda "slap" the lever up/down with my index finger and thumb. Just a short, quick motion to activate the 1/4-inching.
Like you, use it mostly with my BB. Becomes second nature after a while.
It's far from a good feature on BX and some B's, but I've been able to make do.
