Hey guys, worked on my new to me B6200hst today. I attempted to tighten the play out of the 3pt raise/lower lever. Mine seems excessively loose. I could be wrong without any prior tractor experience, but it seems like a pretty obvious realization once you use it.
So, after researching on this great site (which has been as fun as doing the work), I decided to attempt to get to a nut which was suppose to tighten it up. It did not. Which means, next step in the troubleshoot is to replace a bushing and two washers to shore it up, which should be the fix. Before I order them, however, I'm unsure of the procedure for replacing said washers and bushing.
The concern is actually regarding a cover or two under the seat area that look like they will have to be removed. They may or may not have gaskets under them, as well. I'm not even sure what they are for... Can anyone tell me the procedure for replacing this bushing and washer correctly? I've found a blow up of the parts in question while researching this fix, and attached it. Also, a few photos of the tractor itself. Thanks for your help.
