2005 B21 No start. Bought it with a broken rear diff and missing ignition switch last year. Put a new ignition switch in it, turn to on, and jump the starter relay, tractor started right up. I know some of the safety switches were not hooked up at the time I started the tractor ~9 months ago.
Did the entire rear-diff job, its all back together now and no start.
The fuel cutoff solenoid is not getting any power. The manual I have with wiring diagrams is not 100% accurate, it shows 3 wire cut off solenoid, this tractor is 2 wire, both red/ black.
Where should I start on this? The solenoid should be getting power with key turned to accessory position correct? Is the new ignition switch bad ? or is it a controller issue?
