2" Tow Ball Attatchment...
RLinNH
B2650,LA534,BH77
Mar 10, 2018
68
10
NH
Looking to move my snowmobile trailers around the house with my tractor. Only option I have seen is to drill a hole in my front end loader and place the ball there. Really don't like that. Anyone here have something different?
RLinNH
B2650,LA534,BH77
Mar 10, 2018
68
10
NH
Thank You. Just ordered one. This means I gotta get familiar with taking off my backhoe...:eek:
RockPileGardener
BX2380, loader, snowblower, mowing deck, bagger
Mar 13, 2019
Canton, CT
I bought a Heavy Duty 3 Point 2" Receiver from Tulga Fifth Wheel. I takes the same ball that I use with my truck. I also bought a ripper that mounts in the 2" receiver. Additionally the 3 point hitch receiver has a nice loop that I use to pull up small trees with a chain. Having all these work off the 3 point hitch makes it really versatile. It may not have the same lift range as the FEL but it still has a lot of lifting power. And moving a trailer around is more natural when the trailer is being towed instead of pushed with the ball in front of the tractor.
Just my experience so far.
DC
SidecarFlip
Banned
554
Both my buckets are drilled for a ball mount and my hay spear(bucket spear) also uses the hole in the bucket. No big deal for me.
3,279
Lil Foot... How do you see the ball well enough to make the hitch-up?
Would making such an adapter to fit the TOP of the bucket work better?
(I do REALLY LIKE your adapter idea.)
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
215
I move trailers to mow around them and don't want to remove an implement to put on the ball mount. I got one of these for the Quick attach front loader.
Here is where to get them.
Tughill Tom
B3200
Dec 23, 2013
1,198
1,297
Turin, NY
Having it level is the key to removing and installing back on. I block up mine with jack stands and ratchet strap the legs in the up position, saves on space.
2,444
No problem, visibility is good. I just roll the bucket back a little to see the coupler, then level it out for towing. The tongue height on most of my trailers is pretty low, not sure if I could get under the coupler if the ball was on top of the bucket.
2,444
My neighbor bought a new hitch receiver that bolts to the top of the bucket, and found he could not get low enough to get under the tongue of his dump trailer. He borrowed a stinger with a 6" drop so he could hook up the the trailer.
FTG-05
Jul 21, 2013
273
107
TN
I made this up one afternoon. Works fine and I use it a lot.
M
I made one of those years ago, never used, never will. If someone wants it, come get it.
I'll take some pics of it later.
