Checking Hydrulic Fluid
msmcknight
75
Statesville, NC, USA
Hi guys,
I'm a new tractor owner and am still learning. I have a B2601 and I've tried to check the hydrolic fluid at the rear of the tractor and in the front axle. But, I can't see it. It's like trying to see water against a yellow background.
Do you guys have any tricks you can share that will make the hydrolic fluid more visible against those yellow dipsticks?
Do they make colored hydrolic fluid?
Sorry if this is a silly question.
Thank you,
-Michael
1970cs
1,124
Grand Ledge
Re: Checking Hydrolic Fluid
On any type of dipstick, I use the feel from running my finger from the top down till I feel moisture! Of course wipe the complete dipstick down before re-inserting.
I would not suggest coating the tip with anything being that it could flake off.
Pat
torch
Jun 10, 2016
2,614
859
Muskoka, Ont.
Angle the dipstick and look for the difference in light reflection. Or touch the stick with a piece of coated white cardboard (paper is too porous and the oil will wick, giving a false reading).
6,134
Times two on this advice :D:D I
Vacula
BX1500, LA181, 54" MMM, JohnnyPlow Sr, Heavy Hitch, Box Scraper
May 10, 2017
76
Clinton County, PA
Yup! Cheaters but............I found that a small powerful flashlight like the ones I use to look down the bore of a rifle, can show you the level.
Place the flashlight on an object the height of your hip or higher. (saw-horses, portable workbench), turn the flashlight on and lay it down on it. Next pull the dipstick and take the stick right over to the flashlight. A small powerful beam will easily show the level on the stick without saturating everything around it.
It's easier to check them in the winter when they are a tad more viscous. I use this method in the summer when I have a hard time seeing the wet from the dry.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
77
Rocky Face, Georgia
The only silly question is the one you don't ask.
At some point in time all of us were tractor newbies.
Hyd fluid is hard to see on any dipstick. Biggest thing is have the tractor sitting as level as you can get it then find the right angle and light source to see fluid on the stick.
Stmar
B2650HSDC
May 23, 2017
922
45
Buffalo, Wyoming
It definitely is hard to see, may take me a few times to get a good reading. Is this normal? You read it just in the good zone when cold but when you check after running the level is higher on the stick?
