So I am new to tractors, just got a bx23s. auto trans, and 4WD.
I am wondering about what type of use or should I say improper use may damage or put a lot of wear on the transmission, especially when using the front bucket and pushing into piles, and actions like that where you are pushing up against something and using the forward motion of the tractor.
I have no Idea what type of automatic clutch there is in the drive train, and if it is designed to slip with out damage?
I would like some advice on how much pushing you can do with a machine like this when you are pushing up against a pile and using the forward force to help dig the bucket in. With out doing any damage to the machine.
And also if it is recommended or not to use the 4wd for actions like this even if the ground is not slippery.
Thanks
Thanks
