I have a 2004 L48TLB HST. South Texas summer temps are normally 100 degrees plus. What would be the best Trans/Hyd fluid for such high temps. Thanks
Synthetic........I have a 2004 L48TLB HST. South Texas summer temps are normally 100 degrees plus. What would be the best Trans/Hyd fluid for such high temps. Thanks
I'd be curious about what's really going on with this. SUDT2 should handle heat way better than regular UDT fluid.This past winter I put sudt2 in my L48TLB, worked fine till summer got here. 100+ amb. temps it lost a lot of power. Went to my my semi local Kubota dealer which is 60 miles away an bought standard UDT. The dealership doesn't stock sudt2 due to our local temps, and the issues the customers were having with it during the summer. Just ran my L48 with UDT and everything is back to normal, of course it is only 99 degrees right now.
Sounds like there is something else going on. Is the radiator and oil cooler good and clean. Sounds like something is overheating.This past winter I put sudt2 in my L48TLB, worked fine till summer got here. 100+ amb. temps it lost a lot of power. Went to my my semi local Kubota dealer which is 60 miles away an bought standard UDT. The dealership doesn't stock sudt2 due to our local temps, and the issues the customers were having with it during the summer. Just ran my L48 with UDT and everything is back to normal, of course it is only 99 degrees right now.
