I bought a used L2061B snowblade for my old BX2200. It has obviously been remade at least once to fit various tractors and it included a power hydraulic pack which is need for my BX, since there is no auxiliary hydraulics on it and this would be so much easier for me. All the cylinders worked on the unit when I bought it but there was an obvious problem with speed of the power unit. It turned out the solenoid was corroded, sending a poor current to the motor, so that was replaced. Now, everything works great EXCEPT, I cannot get the blade to turn right. It is supposed to have: power up, gravity down plus power left and right with a total of 3 cylinders.
I've spent hours on this and need help. I disconnected the hoses to the left & right cylinders and they are not seized. They turn either way without power.
I have tried switching wires, even though nothing was changed, just leads cleaned and replaced where necessary due to corrosion. All wiring has been checked for continuity and all is good. It can't be the solenoid otherwise nothing would work. I've attached wiring diagrams and photos and would appreciated your help. The empty plug on the left/right switch seems obvious but it was never altered and no wires were removed.
Yellow allows blade to go down
Blue
Green
Orange 12v to solenoid switch
White 12v power to hydraulic motor
I've been using the plow with the blade turned left but would really like to get it working correctly.
Thanks, Doug
Blue
Green
Thanks, Doug
