I bought the Kubota brand 2 bolt spinner knob for my BX1800 tractor and immediately stripped out the bolt threading thru the steel insert trying to get it to grip the round steering wheel and not lean inwards towards the middle. After rethreading the insert to the next size bigger bolt, I lined up the one side with the steering wheel crossbar and drilled a hole thru the flat area. Then I clamped the spinner knob on like normal but with the inside bolt going thru the flat bar of the steering wheel between the two halfs so it can no longer twist around. Works like a champ and will never slip around the steering wheel.
