A work in progress (5' Boom Pole)
olthumpa
L275
May 25, 2011
1,501
Maine
A work in progress. Still a few things to do. :)
Think I have over engineered it for my tractor.
5,916
Re: A work in progress
We were just talking about one of them for the SSQA on my loader for setting trusses, great job! :D
Nice use of rail tie clips. ;)
Clippy, It's a 3 point boom pole.
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
To me, that's equivalent to saying, "I think I put too much whiskey over my ice."
Although I can't envision all the functions, I'd copy it if I had the material. And I likely will, when a boom pole percolates higher on my list.
But... haven't you heard that scientists have determined that the Loc Ness monster couldn't have lived in the lake, given the lack of forage and type of water? I think your next steps will need to be to build a submarine around it so you can go after the giant squid that attacked the Nautilus.
2,428
Useful tool !! What say you beef up that gusset ??? That is the only weakness in the picture!:eek::D:) - Hate to see what weights you gonna need on the front end when you go about picking up something......heavY:)
olthumpa
L275
May 25, 2011
1,501
Maine
Was wondering if anyone would know what they were. :D
Ice in whiskey:eek: :eek: :eek: that is why they invented freezers - that is where you keep your whiskey. Huuumm, that sounds good right about now!
I have wanted a boom pole for quite a while so while I was watching the paint dry I figured I would start on it.
That is part of the work in progress. Haven't decided if I am going to gusset the pole or use two pieces of angle iron from the base to the pole forming a triangle. Either way, it does need additional bracing.
5,233
I thought that was a flexible design counter weight. Just hook more on the far end as you hall more in the bucket.:D
5,209
996
If you can move the corner brace out further it will add greatly to the strength.
My black in in your photo illustrates my suggestion.
Dave M7040
coachgeo
Nov 16, 2012
2,460
35
Southern OH
Re: A work in progress (3' Boom Pole)
Title Edited. added "3' boom pole" to title. This makes folks searches on this topic more relevant.
A site's archive is only as good as how searchable it is. A good archive is in best interest of our members
3,222
That looks like belt line rail, and track clips,, hmmm you don't work around a mine some place do you??:confused: It looks like she should take just about any thing your little beasty can lift,, good deal
olthumpa
L275
May 25, 2011
1,501
Maine
The top is 51" + 4" for front hook = 55"
If you add the 4" for top link attachment tabs = 59"
Nope, no mind around me.:p:D
Pole = 3/16" X 2.5" X 2.5" X 51" re-purposed torsion axle tube.
Upright = 3/16" X 2.5" X 2.5" X 27" re-purposed torsion axle tube.
Lower brace from upright to boom brace = 1/4" X 4" X 4" X 25" angle iron.
Hooks = re-purposed rail clips.
Base = re-purposed 1979 Fisher Plow Conventional Pushbeam.
Bracing from Pushbeam to upright = 1/2" plate.
Hooks = rep-purposed rail clips.
2 large thick washers to reinforce pushbeam where holes were drilled for the draw pins.
1+ lb of welding wire.
bearskinner
Sep 1, 2014
925
241
N. Idaho
Its never over engineered or overbuilt if it works or what you intended it to do
"Over Kill is Under Rated"
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
10
Lovells, Mi
We used to call that kind of over engineering: "Hell for looks, but it sure is strong.":cool: That is not a comment on the looks as it looks great for what it is intended.:):):)
5,916
Excellent build. :D
I would only add one piece, but you may not need it, it would be a strap that wraps from the upright beam to the top beam, as all the force in on that corner and with an open box beam it can just tear the bottom of the box off. ;)
olthumpa
L275
May 25, 2011
1,501
Maine
Excellent build. :D
Is this where you are talking about? I ground the upright and recessed the top beam into it. I can easily add a strap if you think it should have one.
Thanks
hurleyhuckster
24
Kingston, NY
Can anyone please explain any uses of this implement that would be preferable over a FEL or BH?
This post just schooled me on the existence of said implement, now i am just trying to understand it.
I can certainly see its usefulness for lifting stuff, but does it really only make sense to own one if you DONT have a FEL or BH?
Thanks in advance!
5,233
"but does it really only make sense to own one if you DONT have a FEL or BH?"
hurleyhuckster, if you don't have a FEL or BH you can attach the boom pole to the 3pt arm on your tractor (with a top link) and lift things much easier then bending you knees and grunting!!!!!
6,144
They also come in handy if you can't fit into an area with the fel :D
