Big Orange
L3650 GST LA650A FEL Howse 60 inch bush hog, Kubota L 321 60 inch snow blower
Have not posted in a while but weird thing happened. I had the tractor warming up for a few in the yard and then went to move it to plow, the transmission was in 3rd gear (GST) I throttled it up let out the clutch and nothing happened. I shifted to reverse and nothing. I then moved the shift to 4th and went fine, then back to 3rd and it was then fine as well this one item has not happened again. A couple days later I was plowing in 4th and tractor was moving but very slow after really warming up it seemed fine. I have just added the plow and hydraulics to the rear remotes for the front bucket mounted plow. I also blew a line the other day. I checked the fluid and with all sitting idle and rams all retracted the super UDT 2 fluid level is just above the bottom line on the site glass. Is all this possibly just low fluid? I did notice when I angle the plow and raise the 3 point counter weight all the way up as well as tilt my bucket and raise it for plowing the fluid is barly in the sight glass.
Any help would be greatly appreciated
Thanks
Thanks
